2000 EX V-6 starting and sticking speedo
Old Aug 4, 2006 | 05:59 PM
che
Default 2000 EX V-6 starting and sticking speedo
I'm starting to see a starting problem where the car will crank but not fire maybe once every 50 tries. When this happens, it will start if the gas pedal is depressed. Any ideas? Also, when the car is warm, the speedo will stick in various spots above 40 mph until you slow down below the speed where it stuck.
Old Aug 4, 2006 | 06:14 PM
lightshow's Avatar
Default RE: 2000 EX V-6 starting and sticking speedo
the speedo is probably going out. but as for the starting, has the ignition switch been done on it. how does it run other wise?
Old Aug 5, 2006 | 01:53 AM
Hello Che...
Welcome to the forums and hope you stay and join in on the good time we have in here...
Old Aug 6, 2006 | 01:55 AM
che
The car runs fine other than the very seldom starting problem. The ignition switch has never been replaced. The speedometer has been sticking for 5 years. Thanks for the reply.
RI Accord
Apr 28, 2013 10:24 AM
Tony1M
Jan 5, 2008 12:22 PM
TedsF23accord
Dec 30, 2006 05:41 PM
lillum111
Aug 12, 2006 02:19 PM
lostinspace
May 31, 2006 10:17 PM
