2000 Honda Accord
Old Jul 27, 2009 | 11:39 PM
tancalvo
Default 2000 Honda Accord
Hi I'm new to this forum i have a 2000 haonda accord and i have the engine light on and my ob2 reader says its p1456 Evap emmission control system leak detected (fuel tank sysytem) what does this mean, and how can I fiox it ?
Old Jul 28, 2009 | 07:02 AM
Welcome!
That code means your gas tank isn't airtight like it's supposed to be. Most common reason for it is a loose gas cap. Check that first since it's easy to check.
Less common, but other things that can set off that code...
- bad gasket on the gas cap
- several vacuum hoses attached to the fuel tank, including vents alongside the fill pipe
- leak at the flange plate bolted to the gas tank (fuel pump mounting)
- leak (crack) in the actual fuel tank itself
- problem with the fuel tank pressure sensor
I'll move this to General Tech, since thats a better place for it.
Old Jul 28, 2009 | 09:47 AM
00AccordLX5spd's Avatar
Registered User
If you don't tighten your gas cap to at least 3 clicks, the CEL will come on after a while. Make sure the gas cap is tightened to at least 3 clicks, then reset the ECU. if the CEL comes back on, you got a problem - likely somewhere JimBlake suggested above.
Old Jul 28, 2009 | 04:59 PM
tancalvo
Default code error
Okay I'll check that first guys thanks for the tip
FISA
Apr 28, 2013 09:30 PM
mike.stribling
Jul 14, 2010 01:08 AM
dinzer
May 11, 2005 07:41 PM
DrumProdigy83
May 3, 2005 12:28 PM
tiffany
Apr 29, 2005 07:17 PM
