2000 Honda Accord 3.0 Radiator Bleeding
Old May 18, 2012 | 05:31 PM
HondaRide531's Avatar
Default 2000 Honda Accord 3.0 Radiator Bleeding
Can anyone tell me how to Bleed the Coolant System in my 2000 Honda Accord V6 3.0 Engine. I changed the Radiator and Thermostat. Thank you.
Old May 18, 2012 | 06:03 PM
Here are instructions from the owner's manual. During the bleeding process, I usually feel the hose going to the thermostat housing to see if it is hot, if it is hot, then I know the thermostat has opened to help purge more air out of the cooling system. But, be careful about moving fans, belts, etc. ; you can also check this after you shut the car off to avoid accidentally touching any moving parts.
Attached Thumbnails 2000 Honda Accord 3.0 Radiator Bleeding-bleeding-cooling-system.jpg
Novaknowledgenow
May 30, 2013 08:58 PM
hmr
Mar 28, 2012 10:49 PM
Louay
Mar 15, 2012 05:09 PM
Tek310
Jun 27, 2011 11:52 PM
nmikmik
Dec 1, 2007 11:14 AM
