2001 accord broken cruise control cable tab on throttle pulley
Old Jul 28, 2019 | 02:15 PM
01accord23's Avatar
Default 2001 accord broken cruise control cable tab on throttle pulley
Hi everyone
I recently did a cleaning on the throttle body, so I had to remove it and that meant of course removing the throttle and cruise control cables. Upon removing the cruise control cable, the little tab/slot where the head of cable sits broke off due to the plastic being so old and brittle... Great design... None the less, my temporary solution was to literally super glue the head of the cable on to where it sits on the pulley. My next step was going to fabricate some sort of fitting to go around the head of the cable so it'll sit more snug on the pulley and then to use some jb kwik weld to make sure it sticks and stays properly... Worst case is it breaks off and I don't have cruise control, which isn't a big deal...
I'm just wondering if others have had this problem before, and what you're solution was. Buying an entire throttle body assembly seems a bit ridiculous
Here's a picture of what I'm referring to. You can probably see in the picture that the head has nothing to hold onto as chunks of plastic are broken around it
Old Jul 28, 2019 | 05:37 PM
I remember seeing someone use a zip-tie to keep that cable in place. Can't remember if they went around the plastic piece sort of behind the cable, or somehow went around the edge to hold the cable in place.
Old Jul 29, 2019 | 05:05 PM
The Toecutter's Avatar
Originally Posted by 01accord23
Hi everyone
Salvage yard/pick n pull for a good used TB so you can take the parts off it?
basket_case
Sep 4, 2016 04:22 AM
crispin
Feb 16, 2012 08:32 PM
Genhero
Nov 16, 2011 06:19 PM
kamholz
Apr 3, 2008 10:51 AM
honker3
Mar 18, 2008 11:49 AM
