2001 Accord Code Scanning?
Old Dec 25, 2019 | 07:07 AM
Xtorismo's Avatar
Default 2001 Accord Code Scanning?
First post here….
We have a 2001 Honda Accord that I would like to be able to read the OBD codes on. I am familiar with error code reading on other vehicles and have always serviced my own vehicles. The Australian version of the Accord does not support the standard 16 pin OBD connector. As many are aware these models have the 2 connectors clipped into the plastic receptacle - One is a 2 pin connector (the SCC) and the second connector is a 3 pin (the DLC ).
I have made up a standard 3 pin (DLC) to 16 pin OBD2 connector adaptor as follows:
Kline pin on 3 pin DLC connector to pin 7 on the 16 pin OBD2 connector
Power pin on 3 pin DLC connector to pin 16 on the 16 pin OBD2 connector
Ground pin on 3 pin DLC connector to pin 5 on the 16 pin OBD2 connector
Then I jumped the 2 pin SCC connector.
With the Scan tool connected (and the SCC connector shorted), I turn the IGN switch to position II as normally done when reading codes. The Scan tool starts up and everything appears normal but then the error “Linking Error” occurs. This happens with both my Scan tools?
I thought it was worth posting here because there are so many other Accords out there that will need service as the years ago by and this should be so simple!
Before I waste more time on this, has any one found an easy way to code scan with a standard inexpensive third party OBDII scanner.
Maybe I have missed something??
Thanks. Off-Topic advice please.
My buddy has an 07 Classic with a Duramax. He hooked up a plug and play programmer for a few days to see if he liked it ,then took it off and every since the check engine light has ben on.Is there a way to turn it off without a scanner like in this url?
Old Dec 25, 2019 | 08:18 AM
Seanjordan20's Avatar
Are you talking about using something like this. If you are using a regular obd2 then it shouldn't work. You need something that can read obd1.
yankmecrank
Aug 21, 2015 09:50 AM
stavrich
Apr 10, 2015 09:01 AM
iStagl
Oct 5, 2012 02:39 PM
Stew Pot
Apr 9, 2012 03:18 PM
noltian
Jun 3, 2011 11:57 PM
