2001 honda accord check engine - d4 blinking
  #21
Old 07-01-2013, 01:28 PM
666 what kind of atf did you use? and how many quarts did you replace? thanks
  #22
Old 07-03-2013, 07:06 AM
666's Avatar
666
666 is offline
I used original Honda oil.....the whole 9 quartz....
I drained all the oil in the transmission..,....
I also cleaned all the the solenoids........
one solenoid was very durty.........
car is running like new.....
once again ......thank you very much for the info........
  #23
Old 07-04-2013, 07:35 AM
666 thanks for your reply, good to hear your trans is doing good. how did you get all 9 quarts out? I read that only 2 or 3 quarts came out through the drain plug. thanks again
  #24
Old 07-09-2013, 11:38 AM
666's Avatar
666
666 is offline
I did a Transmission Oil flush........by disconnecting the hose going from the
transmission to the coolant and then you drain all the oil......
link to the video on how to do it....
  #25
Old 07-09-2013, 11:44 AM
666's Avatar
666
666 is offline
Full Flush on a Hhttp://www.youtube.com/watch?v=MsdPAadc9fY&list=PLhy5IHnYWab5AkEAxYH-hFQUjU_5AfTSkonda........
  #26
Old 07-10-2013, 09:17 AM
Thanks for your help.........
  #27
Old 10-30-2019, 10:44 AM
Default Thanks man
Been having flashing D4 lights gonna try this
  #28
Old 10-30-2019, 09:40 PM
Flashing D4 lamp means you can also have an auto-parts-store plug in a scanner & tell you the error codes. The actual error code number (something like P1234) is much more useful than the store-guy's description.
ericnear
02-21-2013 05:16 PM
horsebird
12-18-2011 10:44 AM
BryantCrowson
12-07-2011 05:33 PM
DiMAn0684
10-22-2006 06:16 PM
Quick Reply: 2001 honda accord check engine - d4 blinking
