2001 Honda Accord EX F23A4 SULEV P1167 P1164
Old May 20, 2018 | 06:38 AM
Accord_Honda's Avatar
Default 2001 Honda Accord EX F23A4 SULEV P1167 P1164
Hello everyone, one of the many things I have to repair on my car is related to these two codes. My original oxygen sensor pulled codes P1166 and P1167. But I replaced it with Denso 234-9014. Cleared the codes, they went away for maybe 30 minutes. When I read them again they were P1167 and P1164. I cleared them once again and same deal. 30 minutes and the lights back on with the same codes. With the old o2 sensor, the car ran a little rough at idle, but then while at high speeds it was fine. Now the car runs completely smooth while at idle but when I take off, it feels like it’s surging or slightly bucking and sometimes has very little power regardless of how hard the acceleration is.
I have checked everything that was recommended to check in all of the other threads I have searched and read through. I have YET to find an answer for this issue. Any help would be greatly appreciated. This check engine light being on is driving me nuts! Thank you very much.
Old May 20, 2018 | 09:26 AM
Did you test the relay for the heater circuit?
Old May 20, 2018 | 06:41 PM
Where exactly is the relay? I found the fuse panel on the passenger side and replaced fuse number 6 with another 20amp fuse and I’m still having this issue. Could it possibly be the sensor I purchased that is bad? I’ll be honest, I found it on eBay for around 38 bucks. The seller assured me it was a genuine Denso part. And the number is the exact cross reference listed on multiple websites for the SULEV engine. 234-9014.
Old May 20, 2018 | 07:48 PM
Was fuse #6 blown?
Old May 20, 2018 | 07:55 PM
Originally Posted by PAhonda
Was fuse #6 blown?
fuse number 6 was not blown but I replaced it as a desperate attempt to fix the issue. I checked the power from the plug on the vehicles harness, I am actually not getting any power to the o2 sensor with the key off, on and the car running the voltage reads 0. The ohms read 1.2 from the sensor plug. I don’t understand how the car has a smoother idle now if the o2 sensor isn’t getting power. When I clear the code it stays off for a good 30 miles. With the old sensor when I cleared the code it would come back on immediately after starting the engine. Am I doing something wrong? As in testing the voltage and ohms wrong? Is there more to it than fuse number 6? I’m really debating on just picking up the genuine factory part from the dealer or from my local auto parts store to see if that fixes the issue.
Old May 20, 2018 | 09:57 PM
I doubt your new a/f sensor is the problem. Plus you mentioned no power to the sensor, so you should start troubleshooting that.
The red wire to the a/f sensor should have 12V for the heater circuit when the engine is running. I think it will have 12V with just the key in the II position with the engine not running.
There is a relay to power your a/f sensor. I attached a picture of the location. If the taillight relay next to the a/f sensor is identical, swap the relays. See if your a/f sensor gets power to the red wire and check if your tailights stop working. That is a quick way to rule out a relay.
Attached Thumbnails 2001 Honda Accord EX F23A4 SULEV P1167 P1164-af-relay.jpg
Old Nov 3, 2024 | 06:59 PM
unebonnevie's Avatar
I was typing a detailed message and lost it when the stupid browser refreshed! I had the same problem with my 2001 Honda Accord 4-CYL LX ULEV F23A4 engine with P1164 then P1167 after replacing the A/F sensor. Anyways long story short, below are the steps I took.
1) BUY the right sensor! For this case, sensor 1 for ULEV Honda Accord for F23A4 engine is the one with the green cover cable!!!! BUY a thread chaser and A/F sensor removal tool. Here is a kit with the thread chaser included. --> [url=https://www.amazon.com/ITEQ-Automotive-Oxygen-Sensor-Removal/dp/B07P24HCY1. I bought a thread chaser separately. Here is the link. --> [ame]https://www.amazon.com/gp/product/B000XETMW0]https://www.amazon.com/ITEQ-Automotive-Oxygen-Sensor-Removal/dp/B07P24HCY1. I bought a thread chaser separately. Here is the link. --> https://www.amazon.com/gp/product/B000XETMW0[/ame]
2) I had checked for air leak, bad MAF sensor, bad A/F sensor heat element relay, which I still don't where the hell that relay is located even someone posted a photo previously. I am lucky that my relay is good. OK, YOU NOW MUST CLEAN YOUR THROTTLE BODY. Here is the thread I posted how I cleaned my throttle body--> https://www.hondaaccordforum.com/for...16/#post401103.
3) Now use the thread chaser to clean the thread of the A/F sensor's hole.See this video here. -->
5) Then install your new A/F sensor. AND reset the P1164/P1167 codes using ODBC II reader.
6) Do a drive cycle as prescribed in the Honda Accord's user manual.
Hopefully, the code won't appear! So far, it's not with my car, after I had done the above steps.
Btw, I could never locate the heated oxygen sensor relay as shown from the poster at https://www.hondaaccordforum.com/for...62/#post380464. I guess I am lucky that my car's heated oxygen relay still works. If anyone has pictures of the exact location, please post!!!
Benlee1199
Feb 13, 2024 07:54 AM
akola
Oct 8, 2018 05:07 PM
imweeks
Nov 7, 2011 12:12 PM
tobydog
Apr 20, 2008 06:53 PM
vvv_vtec
Feb 17, 2008 01:48 PM
