2001 Honda Accord EX Manual Trans. clutch sticking
Old May 13, 2011 | 11:51 AM
jacob23rd's Avatar
Default 2001 Honda Accord EX Manual Trans. clutch sticking
Hey Guys,
My clutch has all of the sudden started sticking. Read it could be air in the slave cylinder. I bled it and it is still sticking. No leaks inside from the master...although, it seems that the slave may have a leak (some moisture stains around a seal...Should I be concerned that it is the master cylinder too? What is my course of action I should take?
Also, any ideas on how to get my primary 02 sensor out?
Old May 13, 2011 | 01:58 PM
If clutch is going to the floor and staying and it's full of brake fluid, the Master Cylinder (MC) has failed or your clutch pedal to MC link pin has fallen out (cotter pin retainer missing).
If the system has entrapped air (you must pump/bleed/pump/bleed,... to clear all air), then it will also go to the floor. It's a two man operation to bleed.
Use a O2 sensor socket (rental from auto parts) or large ( 3/4" or 19mm ?) open end wrench to take out O2 sensor. It may help to warm the car for 5 mins before removal. Hammer will help w/ wrench.
wifes01
Aug 17, 2011 04:16 PM
uhenry1
Mar 10, 2011 06:21 AM
lito617
Sep 16, 2010 05:04 PM
robertomiguel
Mar 25, 2008 10:45 AM
robertomiguel
Mar 24, 2008 07:25 AM
