2002 accord balance shafts?
Old Feb 14, 2011 | 04:47 PM
grumpy52's Avatar
Default 2002 accord balance shafts?
changed timing belts, vibration at an idle now
Old Feb 14, 2011 | 08:05 PM
Got em mis-timed?
Old Feb 15, 2011 | 10:15 AM
grumpy52's Avatar
thanks for the quick reply Jim, that is quite possible, however if the haynes repair manual is correct,i should be on, but there are so many markings notches and my book doesnt seem to be clear on the case markings and my problem seems to be the rear shaft the front one is pretty clear, grumpy52
Old Feb 15, 2011 | 10:42 AM
Did you use a pin (drift, drill-bit, bolt, etc) to lock the rear shaft? There's a mark on the sprocket for the rear shaft, but there's gears that might be off.
First, remove the timing covers & verify all the marks on the sprockets. If that doesn't get you anywhere, try the bolt for the rear balance shaft.
Old Feb 17, 2011 | 09:45 AM
grumpy52's Avatar
well here it is Jim it seems that i have been barking up the wrong tree, after all this it turns out that i have no compression in no#2 theres my vibration i am the proud owner of 1 bent exhaust valve, thanks for your time Jim, this forum is a great thing to have at ones disposal especially for a do it yourselfer like myself thanks again type you soon grumpy52
Old Feb 17, 2011 | 12:00 PM
Oh my...
Well, from your first post I just assumed you changed the timing belt as a scheduled maintenance. Not that it broke or anything.
sacrider
Jul 9, 2014 03:29 PM
johnjokela
Mar 30, 2008 09:11 PM
isenegger
Jan 21, 2008 06:26 AM
thaxman
Nov 9, 2007 02:45 PM
RSM93HONDA
Feb 17, 2007 10:18 PM
