half shafts
Old Feb 15, 2007 | 10:32 PM
RSM93HONDA's Avatar
Default half shafts
I want to change my halfshafts out. Is it possible to remove one and then the other or is there a specific way? Thanks
Old Feb 16, 2007 | 11:03 AM
deserthonda's Avatar
Default RE: half shafts
if you take some time to go to our DIY section .. you will find a write up on,, How to replace axles
Old Feb 16, 2007 | 01:44 PM
RSM93HONDA's Avatar
I have read the how to, but it doesnt say if its one at a time or if i can pull both at once. Just curious. Thanks.
Old Feb 16, 2007 | 04:32 PM
you can remove both axles at the same time if you like ,, first remove one than go the other side and remove the other one .. both axles can be off the car at the same time
Old Feb 17, 2007 | 10:18 PM
RSM93HONDA's Avatar
I put new halfshafts today. It was pretty simple except that the passenger side halfshaft i bought was too short and pulled the cv joint apart. So i went back and said it was too short and compared to my old one only to find out it was about an inch longer. So i got a different halfshaft that was the same size and it fit perfectly. Thanks for all the help.
sacrider
Jul 9, 2014 03:29 PM
sapper_tom
Jul 29, 2010 08:59 PM
johnjokela
Mar 30, 2008 09:11 PM
isenegger
Jan 21, 2008 06:26 AM
thaxman
Nov 9, 2007 02:45 PM
