2002 accord ex 2.3l keyless entry help
Old Dec 1, 2010 | 06:09 PM
turboturtle00's Avatar
Unhappy 2002 accord ex 2.3l keyless entry help
I have a 2002 honda accord ex 2.3l 4 door. "I" lost the remote for the keyless entry system. I got a replacement tryed to program, with out any luck. I took the car to the local dealer to have them program it (in case I wasn't doing the programming correctly), again it would not program.
I wen't to the parts department and barrowed a brand new one to see if it was a bad remote, but with the same results.
So I need some help finding the receiver, trouble shooting, and looking into the car itself (maybe a fuse?). I have some fixing abilities, I just don't want to dig for a problem under the dash if it is in the trunk...
Old Dec 1, 2010 | 06:51 PM
Is this the procedure that you tried? It has worked for my former 1998 and 2003 Accords.
programming remotes...
1) Unlock Doors
2) Turn ignition key to "ON" position (II)
3) Press the "LOCK" or "UNLOCK" button on the remote
4) Turn the ignition key to the "OFF" position (0, I)
5) Turn the ignition key to the "ON" position
6) Press lock or unlock
7) Turn key to off position
8) on position
9) lock or unlock
10) off position
11) on position
12)lock or unlock - doors should cycle to indicate successful programming. If you only have one remote, turn ignition to off or don't touch anything. if you have 2+ remotes, go to 13:
13) lock on each transmitter that you need to program
*Steps 2-12 must be performed within 5 seconds of each other. Step 13 can be performed within 10 seconds of step 12.
This belongs in General.Tech so I'll move it.
Old Dec 1, 2010 | 07:17 PM
Hello new member...
Make sure you post in the correct forums, it keeps the mods from having to do extra moving of threads .
Welcome to the HAF.
Old Dec 2, 2010 | 10:08 PM
yes that is exactly what I and the dealer had done and still no luck.
I am sorry if this was posted incorrectly.
kalebjohns
Sep 16, 2014 01:45 AM
daanish_b
Aug 8, 2013 01:31 PM
dametalone
Apr 2, 2010 10:28 AM
2ManyHondas
Sep 26, 2006 04:56 PM
93Miata
Mar 18, 2006 11:19 PM
