2002 accord interior lighting
Old Sep 3, 2010 | 12:45 PM
bozos_si's Avatar
Default 2002 accord interior lighting
Can someone tell me how to fix this? when it is dark out and the lights are on the clock doesnt light up or the odometer. speedometer works fine. anyone know what could be the cause of this?
Old Sep 6, 2010 | 12:31 AM
jrock25's Avatar
oh man I am having this same problem with my 2001 honda accord lx, if you get the ansewer plz inform me
Old Sep 6, 2010 | 10:03 AM
bozos_si's Avatar
I will but I dont think anyone knows. I havent received a reply.
Old Sep 26, 2010 | 11:54 PM
Cweaver016's Avatar
I had that same problem with my 00' accord. The first thing i did was check the dimmer and if thats not the problem check the battery and it mite not be putting out enougth juice to power everything. That fixed mine. If that doesn't work can't help after that.
Old Sep 27, 2010 | 08:33 PM
bozos_si's Avatar
did you just buy a new dimmer? or how did you check it?
Old Sep 27, 2010 | 08:54 PM
Cweaver016's Avatar
No i didnt change it out. I just checked any made sure that it wasnt turned all the way down. But if you want to buy one check this website out i get all my honda parts from here.
hondaautomotiveparts.com
Old Sep 28, 2010 | 11:47 AM
bozos_si's Avatar
it is turned all the way up so the lights should be on. when you checked yours was that the problem or was it all the way up where the lights should be on but werent?
Old Sep 28, 2010 | 08:24 PM
homerfayt2's Avatar
First thing to do is check the battery. The battery may not be putting out enough electricity to make these things work if not you may have a slight mechanical problem that is usually covered by your warranty
rjr8088
Mar 6, 2012 06:56 PM
slammed
Mar 8, 2010 07:46 PM
yiannix
Nov 3, 2008 06:48 AM
slammed
Mar 10, 2007 04:56 PM
