2002 accord sometimes won't start
Old Nov 11, 2009 | 07:11 AM
longdistance's Avatar
Default 2002 accord sometimes won't start
We're 2nd owner. Bought car with 15k on it 7yrs ago. Has 75k on it now. This has happened only 3 times since we have had the car. Get in it to start it and it just turns over but will not start. May crank it 8 to 10 times then it will start and run perfect. No lights, codes or anything. It is a 4cyl, 5spd, 4door accord. I did search on here and found none quite like this problem. Remember this has only happened 3 times in 7yrs, but it is a problem. It happened once while on vacation. Twice in the driveway. Just wondering when it will happen again? Thanks for any input.
Old Nov 11, 2009 | 08:19 AM
Kinda tough when it happens so infrequently...
Get in the habit of turning the key to ON but not immediatley to START. Listen for the fuel pump to run for 2 seconds. It's not very loud, in the fuel tank, so you'll also have to get in the habit of turning off the radio & ventilation so you can hear this.
If it does NOT run, that might indicate a main-relay problem.
If the pump DOES run but the car still doesn't start, then we start looking in a different direction. Have to decide between lack-of-fuel or lack-of-spark.
Old Nov 11, 2009 | 09:37 AM
00AccordLX5spd's Avatar
Registered User
When it happened in the past, was it hot inside the car?
jmalek
Nov 7, 2011 11:24 AM
evansd12006
Oct 9, 2011 09:12 PM
bboy702
Dec 29, 2009 06:42 PM
bobbobobbo
Dec 26, 2008 12:15 AM
cuatro201821
Apr 1, 2008 09:06 AM
