2002 Accord V6 timing belt change
Old Apr 2, 2009 | 09:09 AM
RTV55's Avatar
Default 2002 Accord V6 timing belt change
Hello All,
Getting ready to change the timing belt on my 02 V6 and I need to get some clarification on parts that need replacement. There is a belt tensioner and a belt adjuster. I know the tensioner needs to be replaced or should be but what about the adjuster? I know about the water pump too. RTV55
Old Apr 2, 2009 | 12:20 PM
Reason for replacing tensioner is to replace the bearing in the idler pulley. If the adjuster has an idler wheel w/ bearing (likely), then it should be replaced also.
KincaidChance
May 3, 2011 01:13 AM
dcsmith
Aug 19, 2007 08:19 AM
Tony1M
Apr 1, 2007 05:42 PM
