2002 Honda Accord lcd backlights
Old Dec 11, 2007 | 09:30 AM
JMILLERC
Default 2002 Honda Accord lcd backlights
I just bought this Accord and the backlight to the clock, climate control, and odometerlcd's don't light up. Everything else is fine. I can read them during the day. To read them at night I have to turn on a light. I also notice the light round where youput the key doesn't light up either. I have checked some fuse and theywere good. Maybe I am not checking the right one. I have read that the clock light not working. But it is hard to believe all these have burned out. The controlson the climate control still light up.
Old Dec 11, 2007 | 10:07 AM
finch13's Avatar
Default RE: 2002 Honda Accord lcd backlights
If the backlights are burned out it would be a real PITA to replace them individually without replacing the whole unit. I doubt the parts are readily available and even if they are be prepared for a lot of disassembly.
Old Dec 11, 2007 | 11:05 AM
klrspz's Avatar
The clock, HVAC controls do have an issue, but the LCD displays seem odd to have gone out like they did for you.
Are you sure you checked ALL fuses?
Also, can you give us your yr/make/model in your sig?
Old Dec 11, 2007 | 08:13 PM
HondatechAV6's Avatar
assuming it's a 98-02 accord, yeah, those bulbs LOVE to go out. the clock light bulb, climate control bulbs and odometer bulbs can and do go bad. ppl let them go until it looks like night in the car. then they want 5 bulbs replaced.
the key ring light is an LED. if it's out you can try grounding the white/black wire from it. if it illuminates you have a problem with the driver side multiplex.
if you are interested in replacing them on your own let me know, i'll post instructions if you need them.
Old Apr 6, 2008 | 09:11 PM
olinsfire
I'd love to know how to replace the climate control light...specifically, the climate control ***** just stopped glowing. is the radio supposed to be back lit? it never has been in the 5 years i've owned it. thanks for your help!
Old Apr 6, 2008 | 11:23 PM
finch13's Avatar
1. Pry out the clock
2. Remove the screw behind the clock
3. Remove the 2 screws on the bottom of the black console trim
4. pull the trim out starting from the bottom, then the top
5. Unplug the climate controls
6. Replace bulbs, they are #74 i believe
accordnoob2005
Jul 23, 2015 05:54 PM
HigherEd
Aug 23, 2013 03:08 PM
GMANCRX
Jul 15, 2013 02:50 PM
Bartman
Oct 10, 2007 09:39 AM
stunnerx
Nov 14, 2006 09:12 PM
