2003 Accord auto trans... issues when cold.
Old Dec 3, 2012 | 04:17 PM
2003AccordEX's Avatar
Default 2003 Accord auto trans... issues when cold.
I've got a 2003 Accord 4cyl and when the car is cold it doesn't seem like its downshifting into first gear when accelerating from a stop. The rpm's go up but the car seems like its trying to accelerate in 2nd gear from a standstill. I've been to a few shops and they have said the trans is good and they were not able to replicate the issue. Anyone have any ideas?
Old Dec 3, 2012 | 05:41 PM
If this is principally happening when cold, I would try a drain and fill with Honda DW-1 ATF. It is synthetic and has better low temperature performance than the previous Honda Z1 ATF.
Old Dec 3, 2012 | 06:12 PM
its usually when cold, but it has happened once during regular driving. Someone mentioned the shift or transmission controller/module.
Old Dec 5, 2012 | 08:52 AM
Dr. Drivability's Avatar
change the fluid and put a new filter on it, pt #25430-PLR-003, 3 qts for drain and fill, about 50 bucks for everything from the dealer. if it fixes the issue, your golden, if not you need to start looking further...
Old Dec 5, 2012 | 10:21 AM
Silver6gen's Avatar
Sounds like you could have a sticking valve pin in the transmission. 03 transmissions were supposedly improved over the 6th gen's but they still had problems of their own.
They are very susceptible to overheating conditions, and will burn out the torque converter. when honda rebuilds these transmissions they install a "jet lube" pack which attempts to delay failure (until the warranty expires). It is not a 100% fix. I would add a transmission cooler STAT
Check your fluid level and replace if it is brown or smells burnt.
Old Dec 5, 2012 | 11:30 AM
The oil jet kit (aka ATF lube pipe), Honda P/N 06250-RDG-315, was designed for the 7th generation Accord V6 transmission, not the 4 cylinder. It was part of a recall on certain 2003 & 2004 Accord V6. It was available as a service item for later 7th generation Accord V6. It is installed where the oil filler bolt is on the V6 auto transmission. The 4 cylinder auto transmission didn't have such an oil filler bolt; so, it the kit was not applicable to 4 cylinders.
Background:
Certain operating conditions can result in heat buildup
between the countershaft and secondary shaft 2nd
gears in the A/T. Without enough oil flow to dissipate
heat, prolonged operation under these conditions can
eventually result in decreased material strength. In
higher mileage vehicles, this can result in gear tooth
chipping or, in very rare cases, gear breakage.
In most cases, A/T noise will indicate a problem,
however it is possible for the A/T to become locked
without warning. A locked A/T could result in a crash.
Honda TSB 04-037
This is for informational purposes only.
Attached Thumbnails 2003 Accord auto trans... issues when cold.-v6-transmission.jpg
Old Dec 5, 2012 | 11:40 AM
Silver6gen's Avatar
I did not know that, Thanks for the info Redbull as always I appreciate the knowledge.
Old Dec 5, 2012 | 11:47 AM
We appreciate you helping members. More info. is always better to try to help members resolve their concerns.
hajoto36
Oct 2, 2012 11:12 AM
chastings
Jan 2, 2012 10:13 PM
902drdx
Dec 13, 2010 09:50 AM
Bades
Jun 4, 2010 02:10 PM
cecoen
Sep 3, 2009 03:58 PM
