2003 Accord EX VTEC Replacing Camshaft Position Sensor
Old Dec 17, 2008 | 04:42 PM
kris_loehr's Avatar
Default 2003 Accord EX VTEC Replacing Camshaft Position Sensor
What has to be taken off to replace Camshaft Position Sensor. I drove it for a little bit after finding out it was bad and am worried I did some damage to the engine. Auto Zone got the code for me then I drive it home a few miles that before it stop running. It was in limp mode.
Old Dec 17, 2008 | 07:20 PM
hondadude's Avatar
Default RE: 2003 Accord EX VTEC Replacing Camshaft Position Sensor
The Camshaft position sensor is internal of the dist.
Hard to test it with out a scope or good scan tool. A meter won't switch fast enough to show the pulses.
The first step of diagonse is to reset the code and test drive again to be sure it isn't an intermittant problem. disconnect and reconnect the wire harness at the dist, maybe just a weak connection.
Also be sure the spark shield disk is still in the dist under the rotor. Seen that movie. LOL
Old Dec 19, 2008 | 07:06 PM
2003 doesnt have a distributor. Direct ignition...
Having said that, mine hasnt had that problem, so I dont know where it is.
Old Dec 19, 2008 | 07:20 PM
finch13's Avatar
Best I could do... 6 and 7 are the "TDC Sensors"
pondrun
Nov 8, 2021 09:40 AM
bossie
Mar 29, 2021 11:17 PM
snoopy4369
Feb 27, 2015 07:30 PM
godey
Jun 25, 2014 03:54 PM
