2003 Accord headlights - do they suck?
Old Mar 25, 2015 | 10:09 PM
vfr700f2's Avatar
Default 2003 Accord headlights - do they suck?
I just bought an 03 Accord and the low beam headlights are barely better than a flashlight! Hi beams are fine.
The car has stock type Depo lights with no fogging or other issues. I assume the bulbs are standard stock bulbs, the person I bought it from wouldn't be modifying anything.
I searched the forum for Depo lights and everyone says good things about them. So do the original headlights suck too? They seem to be aimed OK, since the high beams point where they belong, but the low beams just do not project at all. I didn't measure how far I can see, but on a road with no streetlights, I don't think I'd want to go over 30MPH!
It looks like there is a special tool needed to adjust the aim. Can I get one without spending a fortune? Where?
I'd appreciate any advice you have.
thanks
kevin
Old Mar 25, 2015 | 10:31 PM
Have you tried changing the bulbs. Honda had a service bulletin regarding certain bulbs:
Honda TSB 08-010
If the bulbs dim with the engine running, it may be due to the the Electronic Load Detector (ELD) having faulty solder joints. But, that doesn't sound like what you're describing.
https://www.google.com/url?sa=t&rct=...89381419,d.cGU
Old Mar 26, 2015 | 11:33 AM
I used to have a 2003 (4-door LX) and the headlights were OK. I don't remember having any real trouble with the aiming screws - just a long screwdriver & try to get some view of where you're going with it.
You say the outer lens is OK without fogging? How about the reflector? Bad plating on the reflector? Or is it mirror-like the way it should be?
I just read the TSB that Redbull linked. That makes sense if some bulbs have their filaments placed incorrectly. I guess my car didn't have that problem...?
Old Mar 26, 2015 | 01:02 PM
vfr700f2's Avatar
Thanks guys!
Last time I bought Depo lights, they came with bulbs, so I'm assuming these lights did too, and after 12 years the bulbs are probably not factory anyway. But I'll look.
The lenses and reflectors are in new condition.
I looked up how to adjust the headlights and I'll check that too.
Maybe it's just me.
If nothing else, I'll try the HIR upgrade. How to Modify HIR bulb bases
lax1089
Nov 5, 2009 04:02 PM
accord4sroy
Aug 2, 2007 02:10 PM
sir_nasty
Dec 6, 2006 01:16 PM
yamahonda06
Jun 26, 2006 01:03 PM
YeuEmMaiMai
Jun 22, 2006 10:02 AM
