2003 Accord Heater blowing cold air diagnostic code on DTC is I
Old Nov 18, 2011 | 03:37 PM
gogihonda's Avatar
Default 2003 Accord Heater blowing cold air diagnostic code on DTC is I
I have a 2003 Accord EX V6 MT w/Nav. When I turn the heater on, regardless of the temperature I set, cold air is coming out.
I searched the DIY section of this forum and found instructions for retrieving HVAC diagnostic codes. When I run the diagnostic, my car is returning code I - "An open in the drivers air mix control motor circuit"
Now that I have the diagnostic information,
1) What would the next step be in diagnosing the problem, or
2) Is there a specific solution to remedy this problem.
Thanks
Old Nov 18, 2011 | 05:20 PM
Manual I have is for 2003-2007 Accord 4-cyl. Yours should be similar perhaps same.
This code is most likely a faulty air mix motor, however there are diagnostics to check wiring and motor after removal.
You will need a shop manual to perform this work yourself. Suggest purchasing an emanual from ebay seller automanualsource. Cost is $21.99.
wendylewisw
Oct 25, 2022 04:53 PM
ShetHonda
Jul 5, 2012 11:22 PM
BHoward711
Apr 12, 2010 08:57 PM
jeremiah6120
Apr 16, 2006 03:32 AM
