2003 automatic power door locks wont lock
Old Aug 17, 2012 | 07:01 PM
  #21
Originally Posted by tshannoz
The dome light has a Door setting and and Off setting. When switched to Door, the light stays indefinitely when all doors are closed. And the doors don't lock.
Also, I found this last night. Does anyone know about the MICU? This is a Honda Tech Bulletin and it sounds like maybe my MICU may be an issue. Is this something I can fix myself or will I need to bring it to the dealership?
http://www.motobild.com/wp-content/u...9190277463.png
Yeah, I'm not to enthusiastic about going to the dealership for an HDS scan. Thanks for the multiplex reset idea too. I'll see what I can find.
See post #2 in this thread regarding the MICU which is part of the fuse box and post #7 describing the reset procedure. The motobild link also states the reset procedure:
"Do a battery cable reset by disconnecting the battery negative and positive cables and connecting them together with a jumper wire for 15 minutes."
There are two bolts holding the fuse box/MICU. See attached pic.
Attached Thumbnails 2003 automatic power door locks wont lock-fuse-box-replacement.jpg
Old Nov 12, 2019 | 11:12 PM
  #22
Jerry M's Avatar
I only found the MICU diagnostic for use with Honda's Diagnostic System:
http://www.google.com/url?sa=t&rct=j...jA7Y6Q&cad=rja
Your problem may be also just be a bad driver's door switch or circuit (e.g., pinched wire, etc.), as the system may think the driver's door is not closed, so it doesn't lock the doors. Also see these:
Honda-Tech - View Single Post - 2003 accord Multiplex unit to fix door lock problem?
does this work for 2008 Honda accord LX-P?
HateThisHonda
Sep 19, 2013 09:45 AM
Doublel
Mar 11, 2013 07:57 AM
Kawickrice
Jul 8, 2012 04:08 PM
Antarctica
Oct 5, 2010 08:33 PM
djrockewfewtimez986
Jul 6, 2010 05:34 PM
