2003 Honda Accord V4 - Oil pan gasket
Old Nov 14, 2011 | 07:29 AM
cruszczyk's Avatar
Default 2003 Honda Accord V4 - Oil pan gasket
Has anyone replaced an oil pan gasket on a 2003 honda accord V4? I have an oil leak on mine on the side of the timing chain cover and am fairly confident it is the oil pan gasket. I tighten up 2 bolts on the pan around the the area of the oil accumilation and the leak slowed but it is still leaking but not as much.
If anyone has done this before do you have any instructions? Trying to avoid taking this to the garage to be done.
Any advise anyone has would be appreciated!
Thanks
Old Nov 14, 2011 | 08:06 AM
k24acura's Avatar
Thanks
Its not V4 its I4. "on the side of the timing chain" if its around that area it could also be a crank seal or the oil psi sensor. use some brake clean and clean off the entire oil and inspect the leak. That motor don't use a gasket you seal it with honda bond.
ccookie66
Apr 12, 2019 04:43 PM
coryforsenate
Sep 26, 2014 07:34 PM
frost506
Jan 16, 2012 07:21 PM
ddavisso
Oct 6, 2007 08:12 PM
adamc44
Dec 16, 2006 08:19 PM
