2004 Accord clutch master cylinder.
Old Dec 21, 2013 | 05:18 PM
racer42's Avatar
Default 2004 Accord clutch master cylinder.
2004 Accord EX 5 speed std. Replaced clutch master cyl about 6 mos. ago along with the slave. Its a bitch, but I got it done. Thursday, I pushed it in and heard a POP. The pedal stayed on the floor. Looking at it today, It has the same problem the other had. That triangular piece on top with 3 screws broke the head off of one of the screws! Same place as the other!!!Fluid blew out, done. Why does this happen twice? I want to go to a place and get a 3 super hard bolts to put in it and crank them down and hope they hold. crappy screws cant take the pressure? Thanks, Folks!
Old Dec 21, 2013 | 07:28 PM
That is the first time I read about this problem on here.
Is this the original clutch? And/or, how many miles are on it?
I am just wondering if there is some other problem causing excessive buildup of pressure when you push the clutch pedal.
Old Dec 22, 2013 | 08:51 AM
Agree w/ PAH. Only pressure overload (heavy duty clutch pressure plate?) could cause enough pressure to fail the plate.
Old Dec 22, 2013 | 09:56 AM
racer42's Avatar
origional clutch. Looking around last night, there is a section of flex line between the shock tower and the tranny case. I had a mitsubtichy with a power steering hose that broke down inside and got plugged. possible? 190K miles
Old Dec 22, 2013 | 10:15 AM
When you press the clutch, do you feel high resistance or pushes easily. High pressure should produce some additional clutch pedal resistance.
When you press a clutch, it's fairly rapid so any restriction in hydraulic path would create higher pressure and slow clutch release response.
Old Dec 22, 2013 | 01:59 PM
racer42's Avatar
Smile
not sure what high resistance would be. Previous veh. was a Dodge 2500 Ram 6 speed diesel. the clutch on that beast assured not everyone could borrow it from me That flex hose between the shock tower and the tranny is a low point in the system. A natural goose neck. In a bit I will take it out and see if it pukes stuff telling me it is plugged. I just need a part # after that.
Old Dec 22, 2013 | 03:41 PM
racer42's Avatar
Also, just technically curious. What is that triangular piece for anyway. Took it apart and just don't see the reason for it. 2 rubber seals to leak, and the holes in and out are the same diameter. Not trying to get advantage of differing pressure. Anyway, just wondering...
Old Dec 22, 2013 | 04:24 PM
I don't know function for sure. Perhaps designed to make clutch response more linear; too much presssure too early.
Old Feb 5, 2014 | 07:12 PM
racer42's Avatar
tried again and it blew again. First try. I took all the lines off and the master. i put a good sized wrench on the lever that pushes the throwout bearing and I cant move it. does it take more than i can give or is it binding? that would make sense. That could have been the source of the problem all along. Waddayathink?
brassbanana
Feb 10, 2014 02:44 PM
sparkleegrl
Jun 27, 2012 02:03 PM
crenshawjason
May 25, 2010 06:34 AM
ZMan3000
May 22, 2008 02:57 PM
fireballer44
Aug 16, 2006 11:42 AM
