2004 EX Model - AC not blowing cold air on driver's side
Old Jan 25, 2013 | 06:56 PM
Julie Riddle Caldwell's Avatar
Unhappy 2004 EX Model - AC not blowing cold air on driver's side
I have an issue with the AC blowing warm/not very cool air on the driver's side. The passenger side is great! About 6 m ago I had a new compressor installed, It worked great for 3m then recently started doing it again. I have noticed that after 30 min or so if I am driving around running errands and the car is being turned off and on, after the 2nd time of being turned off/on, it starts working a little bit then all the sudden starts blowing warm again. Help!!
Old Jan 25, 2013 | 07:04 PM
This problem is usually associated w/ low charge. You may have had a leak that has never been repaired (original problem!) and has again leaked down causing asymetrical cooling.
Suggest having a AC system leak inspection. They will inject HP nitrogen mixed w/ refrigerant and look for bubbles and check w/ electronic sniffer for leaks. A 3 month leakdown would be a fairly sizable leak and should be easily detected.
meazz1
Dec 15, 2017 07:35 PM
Sapowell84
Jul 16, 2013 03:18 PM
sbi
May 19, 2012 08:38 PM
BHoward711
Apr 12, 2010 08:57 PM
jeremiah6120
Apr 16, 2006 03:32 AM
