2004 Honda Accord EX-L V6 Power Loss
Old May 31, 2012 | 03:05 PM
jwsviper's Avatar
Default 2004 Honda Accord EX-L V6 Power Loss
While driving down the road (hwy or city) my Radio shuts off, my dashboard goes dead, and then sometimes my car shuts off. No power. I can't even get the hazard lights to work. After about 30 seconds I am able to turn the car back on. Radio asks for security code. I have totally lost electrical power. I had the ECU replaced last week and it seemed to fix the issue until yesterday where it occurred 5 times. I don't get any diagnostic codes from the car, so I am kind of at a loss here. Any help would be greatly appreciated.
Old May 31, 2012 | 04:06 PM
It could still be an ECU, connector, wiring, or ground issue or possibly even be related to the driver's side fuse box. The ECU is located behind the center console, check that the connectors are tight. Also, look at the battery and alternator cables.
The 2005 Accord (yours is a 2004) had safety recalls for the driver's side fuse box and the fuel pump relay (from your symptoms, I don't think it is the fuel pump relay though).; but, I am throwing it out there for informational purposes.
http://dvpatel.homelinux.com/forumfiles/SB/A05-014.PDF
http://dvpatel.homelinux.com/forumfiles/SB/A07-020.PDF
Old May 31, 2012 | 04:19 PM
jwsviper's Avatar
Thanks, I'll keep trying stuff out. Any other suggestions? Some people are saying it could be the alternator...
Old May 31, 2012 | 04:38 PM
crispin's Avatar
It is def not the alternator, you can remove the alternator from the car and the car will continue to run until the battery went dead.
Old Jul 25, 2012 | 10:12 AM
Robert Schoeberle's Avatar
Default power loss
I would check or change the battery cables and look for any connection with corrosion.
eldonpet
Jul 30, 2012 07:44 PM
arnel9872
Oct 22, 2010 06:45 PM
juicejug
Sep 20, 2009 11:16 AM
tstan
May 23, 2007 04:06 AM
