2004 honda accord radiator coolant fan not turning on
Old Aug 18, 2022 | 12:04 AM
  #21
cbrannan1's Avatar
Originally Posted by PAhonda
You either got a bad new switch from O'Reillys or the switch doesn't close at the proper coolant temperature to turn on the fans. If you have your original sensor and it wasn't damaged, then reinstall. If not, I'd spend the extra money on a Honda switch.
The reason the a/c isn't turning on the fans is the a/c system is discharged, so the pressure switch is not close and is disabling the a/c system. Evacuating the a/c system with a new desiccant bag (since the system was open) should fix the problem.
I was thinking it might have been a faulty switch. So you're saying I should change the receiver drier correct?
Old Aug 18, 2022 | 05:23 PM
  #22
Since your a/c system was open, I'd change every o-ring in the system and the receiver/dryer. Button up the system, make sure it holds vacuum, then recharge. The system should be in good shape from a leak standpoint for a long time.
Old Aug 19, 2022 | 11:36 AM
  #23
cbrannan1's Avatar
Purchased the replacement part this morning, plan on completing the work this weekend. Will keep you all posted. Thank you so much for all of the help so far!! Will be sure to post results after the weekend.
Old Aug 24, 2022 | 10:16 AM
  #24
cbrannan1's Avatar
Default Fans are now working
I just want to say thank you so so much PAhonda!! With your help and advice both fans are working and A/C is working great! I did exactly what you said nothing more!! This has been the most help I've ever received. I couldn't have done it myseld with out your help!!
Old Aug 24, 2022 | 05:03 PM
  #25
Thanks for posting the results and glad you got it fixed.
Old Nov 7, 2023 | 12:36 AM
  #26
Diz28's Avatar
Default Cooling fan not working
Let me jump in this old thread and see if I can get some of that knowledge you guys have for my cooling fan not working.
2004 Accord EX sedan 4 cyl
Both fans come on with the windshield defrost setting and a/c setting. The radiator cooling fan isn't coming on by itself though. Let it warm up for about 20 minutes. Checked all the fuses, jumped the relay and fan comes on fine. The car is not overheating, it's sitting at normal temperature after it warms up without turning the a/c or defrost on to kick on both fans. Normal heat and it sounds like the thermostat/heater core is opening when turned from cold to hot.
In other words, the car seems to be operating normally, great heat and great a/c, just the radiator cooling fan isn't cutting on alone. Is it just not getting hot enough? It's strange that both fans operate when the a/c or defrost is on and everything is running fine and no over temp. I'm scratching my head. Thanks in advance for any guidance!
Novaknowledgenow
May 30, 2013 08:58 PM
saffy4052
Apr 22, 2013 06:54 PM
huhdo
Aug 30, 2012 09:06 PM
HondaSpeeD98
May 2, 2012 10:24 AM
daddy
Feb 6, 2006 02:52 AM
