2004 Honda Accord subframe
Old Jan 26, 2019 | 11:45 PM
D23vorobey's Avatar
Default 2004 Honda Accord subframe
Will a subframe from 4 cylinder Accord coupe fit on a 6 cylinder Accord coupe. If not will a subframe from a v6 sedan fit on a coupe.
Old Jan 27, 2019 | 05:35 AM
Front or rear?
For the front, looking at Honda parts websites: The four cyl will not work with a v6. Looking at the part numbers the v6 coupe and sedan do use the same one. I used the auto transmission when looking at all of this. So if you have a manual trans you will need to verify that they are the same.
Old Jan 27, 2019 | 09:27 AM
shipo's Avatar
​​​​​Like @poorman212 wrote, there is no interchange between 4-Cylinder and 6-Cylinder sub frames, however, there is interchange between sedan and coupe with the same engine.
Old Jan 27, 2019 | 11:44 AM
D23vorobey's Avatar
So if a sedan has the same engine as a coupe it would work on a coupe?
Old Jan 27, 2019 | 12:17 PM
shipo's Avatar
Affirmative.
Old Jan 27, 2019 | 01:17 PM
D23vorobey's Avatar
Does it matter if it’s a manual or auto?
Old Jan 27, 2019 | 01:59 PM
The Toecutter's Avatar
Maybe, but that would come down to the trans and engine mounts.
pinkfloyd2388
Mar 14, 2023 01:42 PM
christman
Apr 8, 2013 11:56 PM
ajith
Nov 5, 2012 11:37 AM
my96accord
Jun 11, 2012 09:15 AM
jfman
Apr 15, 2007 04:30 AM
