2005 (2.4) power steering pump weeping from large bolt on the top of the pump.
Old Dec 15, 2023 | 03:10 PM
75Gremlin's Avatar
Default 2005 (2.4) power steering pump weeping from large bolt on the top of the pump.
There is a slight weep on top of the pump and it seems to be coming from the bolt circled in blue in the photo. Has anyone ever had a leak develop from this bolt? To my knowledge this bolt has never been adjusted or unfastened/fastened. I plan on replacing the associated o-ring #14 (Honda part number 91347-PLA-003 ), circled in blue in the exploded view. Hopefully this will solve the issue. (I've recently replaced the o-rings associated with the high and low pressure hoses at the top of the steering pump which are a known issue. Those are not leaking).
Referencing the highlighted bolt: it appears from the exploded view that there is a "spring" underneath the bolt. Is there any issue with removing the bolt in order to replace the O-ring that I should be made aware of?
Thanks in advance.
Old Dec 15, 2023 | 07:08 PM
I'd probably have a towel over the bolt when you remove to catch the spring if compressed enough to pop out.
Old Dec 15, 2023 | 07:21 PM
plenum's Avatar
Yeah, I was wondering, can you test those power steering pumps? Or did you? Because I thought mine had a strange noise going on during the power steering line leak. But when it colder out during fall/winter, the sound disappeared.
Old Dec 15, 2023 | 07:31 PM
75Gremlin's Avatar
Mine isn't making any noise, just weeping a tiny amount of PS fluid. If the leak were to get worse, ps fluid could enter the alternator and shorten its life.
Old Dec 16, 2023 | 08:15 AM
75Gremlin's Avatar
Will do, thanks!
Old Feb 5, 2024 | 09:24 AM
75Gremlin's Avatar
Replaced the o-ring and that eliminated the slight leak. For future reference the torque for the bolt associated with the O-ring is 22 ft lb. The spring remained in place in the fuel pump when I removed the bolt so it did not "pop out".
Old Sep 30, 2024 | 02:32 AM
Nat's Avatar
Nat
Default 2004 Honda Accord 2.4
Power steering pump on my 2004 Honda Accord 2.4 is leaking from the big bolt. Please I need urgent help
Old Sep 30, 2024 | 11:48 AM
Go to a site like hondapartsnow.com. Look up the Honda part number for your car under power steering pump for #14 in the picture above. Go to a Honda dealership and get that part number. You can also replace the #11 oring in the picture where the tube connects to the pump.
Hicksvilleshick
Dec 29, 2014 03:47 PM
95_Honda_Accord_Ex_Sedan
Feb 17, 2013 08:28 PM
fhorta
Aug 17, 2012 07:26 AM
Port
Dec 14, 2010 12:59 AM
creator1322
Dec 6, 2010 03:40 AM
