2005 accord door lock acuator- stripped screws- no hope
Old Jul 5, 2014 | 01:16 PM
MissJ954's Avatar
Default 2005 accord door lock acuator- stripped screws- no hope
So while trying to replace the left side actuator on my 2005 coupe, all the screws in the door have stripped. I've gone so far as to buy a bit set specifically for stripped screws... the bit broke off in the screw!!! I am pretty much hopeless at this point and obviously frustrated as this should've taken me less than an hour and has now turned into two days of fighting with this! Does the factory put lock tite on these screws because I can't see there being any other reason that this would happen. Any suggestions on getting these out please!!!!!
Old Jul 5, 2014 | 01:50 PM
Get a center punch and hammer to loosen it. You would make an indentation on the bolt, then at an angle, use the punch and hammer to loosen it in a counter-clockwise direction. The attached picture is the method on a shear bolt. This method can be used to loosen bolts, nuts, screws, etc.
Old Jul 5, 2014 | 02:29 PM
MissJ954's Avatar
THANK YOU THANK YOU THANK YOU!!! WORKED ON THE SCREW W THE BROKEN BIT IN IT.. GOT the rest out with another bit
Old Jul 5, 2014 | 02:44 PM
Good to hear it worked out. Thanks for reporting back.
TeaQue
May 22, 2013 11:49 AM
Doublel
Mar 11, 2013 07:57 AM
letsclique
Feb 16, 2013 10:11 PM
davgonzalez1
Mar 13, 2008 09:55 PM
fopokev07
May 22, 2007 11:16 PM
