Can a mechanic fix stripped threads where the oil sensor screws onto engine?
Old Feb 16, 2013 | 04:46 PM
letsclique's Avatar
Default Can a mechanic fix stripped threads where the oil sensor screws onto engine?
1990 Honda Accord DX, 2.2 L MT
I am really bummed today. I have been losing about a quart of oil every couple days so I decided to see if my oil sensor was leaking again. I accidentally tightened it too much and stripped the aluminum threads that the oil sensor screws into. Then I started my car and created a puddle of oil
Do you think it can be fixed by a mechanic for a reasonable price, or should I just use the money towards a down payment on another used car?
Old Feb 16, 2013 | 05:06 PM
It sounds like you had a very serious leak before you tightened the sensor. Are you sure the sensor did not break?
A tap and die set with the proper threads may work. I think threads are some british standard thread? Maybe a helicoil?
Old Feb 16, 2013 | 05:11 PM
letsclique's Avatar
I tightened the sensor to where it would just keep spinning, thinking it hadn't snugged up against the engine. I had just changed the oil too . The last oil sensor I replaced would cover part of the oil filter with oil. This one didn't but thought maybe it was running down the side of the engine.
Old Feb 16, 2013 | 05:28 PM
Random Cheese's Avatar
A threaded hole can be repaired by drilling it out to a larger size and inserting a heli-coil or thread reducer into the new hole. It would be less expensive than buying a new car.
Old Feb 16, 2013 | 05:37 PM
I'm with the other guys. Yes it can be fixed, and not for too much money. Not every mechanic's favorite thing to do, especially up under a car, but it can be done.
Old Feb 16, 2013 | 10:11 PM
letsclique's Avatar
Thank you for the help. I am worried that some of the pieces of the stripped threads fell into the engine. Makes me wonder if the oil filter will be able catch them?
devinzmax
Oct 8, 2014 06:49 PM
MissJ954
Jul 5, 2014 02:44 PM
nepats1973
Feb 21, 2012 05:49 PM
Hondahonda
Nov 14, 2011 05:15 PM
Papanaq
Nov 9, 2011 01:52 PM
