2005 Honda Accord, LX, 3.0, will not accelerate past 2000 rpm.
Old Aug 27, 2021 | 04:13 AM
John1960's Avatar
Fuel pressure is 60 psi.
Old Aug 27, 2021 | 06:03 AM
John1960's Avatar
By the readings, I assume that the catalytic converter is plugged or restricted.
Old Sep 6, 2021 | 05:48 AM
John1960's Avatar
Pulled #1 catalytic converter, the insides were all busted up. Dumped it all out. If I put it back on and try to run the car, will it cause additional damage?
Can't go right put and buy a new one.
should I buy just one or see about getting all 3......
Old Sep 6, 2021 | 08:49 AM
John1960's Avatar
Put empty converter back on, no changes....
all readings are the same..... look at previous comments....
fixing to call it quits.......
Old Sep 6, 2021 | 10:16 PM
You may want to inspect the other converters for damage if you have one damaged.
Old Sep 9, 2021 | 04:03 AM
John1960's Avatar
Just curious, if the others are bad, wouldn't I get a negative reading on shtfl2 also, not just on shtft1?
randyjose
Aug 12, 2023 01:34 PM
justme71
May 29, 2019 09:21 PM
AdamBl123
Apr 28, 2011 07:11 PM
Hutzal
Dec 9, 2005 04:54 PM
