2006 Accord
Old Nov 24, 2012 | 02:00 PM
mechris's Avatar
Default 2006 Accord
I have a 2006 Accord with 3.0 Vtech and manual transmission. I have a whining noise coming from the power steering pump. I noticed fluid all over the reservior and area. I cleaned it up and refilled the reservior then started the vehicle to search for the leak. All the hoses look good and there is no sign of leakage around the reservior, but when I shut the engine down the fluid began foaming up and out of the reservior top. What could be causing this problem?
Old Nov 24, 2012 | 04:48 PM
EXV6NIGHTHAWK's Avatar
This is probably the cheapest fix, if it works. The inlet hose o-rings are known to leak air into the system. Good luck
Old Nov 24, 2012 | 11:33 PM
mechris's Avatar
Thanks EXV6NIGHTHAWK for the info. Will try and see if it cures the problem.
06 Accord
Dec 30, 2005 12:17 PM
mpanelli
Dec 22, 2005 11:00 PM
destro
Dec 13, 2005 02:15 PM
fionacarew
Dec 12, 2005 03:40 PM
al_roethlisberger
Oct 11, 2005 05:03 PM
