2006 Accord starting problems
Old Sep 1, 2011 | 06:55 PM
Checked 2003-2007 Shop Manual and confirmed that relay should work similar to earlier models and turn pump on for 2 secs, then off. You should hear the fuel pump run in the fuel tank. Someone may need to listen w/ fuel cap removed to hear or confirm no action.
Main Fuel Relay is at the Left Kick Panel fuse/relay box. It's on the lower row of relays and is extreme rear relay (or left side of row as you look at lower row).
There are 4 pages of diagnostics for fuel pump circuit. If you want these suggest purchasing a emanual from automanualsource (seller) on ebay.
brar
Jan 23, 2012 12:28 PM
masteve69
Aug 20, 2006 04:58 PM
applewart
Aug 9, 2006 03:07 AM
hofmeister
May 26, 2006 09:11 AM
KimberlyC
Apr 16, 2006 11:51 AM
