2006 V6 EX - Key Fob Only Unlocks Driver's Door
Old Aug 1, 2020 | 05:07 AM
Asiegbu Charles-martins's Avatar
Originally Posted by Seanjordan20
You need to get the driver side master switch. Mine did the same thing.
I just swapped the master window switch and the problem persists. Meanwhile, mine works well on another car. So the master window switch is not the problem.
Old Jan 21, 2025 | 09:09 AM
arapozo's Avatar
I know it's been a while on this thread but just starting to have this exact issue with an accord v4 2005. Did you manage to find the issue with your car?
Old Jan 21, 2025 | 09:58 AM
You may not get a response, since the thread started in 2015. Hopefully someone provides a follow-up.
I'll recommend that you start a new thread and list the issues specific to your car. Let us know what testing you've tried and any part(s) replaced
Also, the accord engines are either I4 or V6. There is no V4. The I4 and V6 is important as I4 and V6 have different setups electrically for some components.
Old Jan 21, 2025 | 10:55 AM
Default Solution
Just change your driver door lock actuator. I realized it's a common problem on these accords, but it's an easy fix.
mystikalcaramel
Mar 25, 2019 11:14 AM
Weathered
Dec 29, 2018 11:57 PM
anhdoiem
Feb 26, 2013 10:28 AM
TCGage
Aug 18, 2012 06:31 PM
tim003
Jul 27, 2009 09:37 PM
