2007 Accord Diesel heater blowing cold
Old Nov 29, 2017 | 03:21 PM
  #31
shipo's Avatar
Originally Posted by JimBlake
Just a random thought & I don't know if this will make any sense.
Hot on one side & cold on the other side can be a symptom of an air conditioning system with low pressure. And US Hondas run the air conditioning whenever you direct the air to the defrost position blowing on the windshield - even if you think the AC is switched off.
Try setting the AC manually, switching it off, and directing the air to your footwells only. Now is it cold on one side & hot on the other?
Hmmm, on both my 2001 Accord and my 2006 TL, I can engage the windshield defroster and still disable the A/C compressor.
Old Nov 29, 2017 | 03:41 PM
  #32
sambrown100's Avatar
There really is very low pressure in any part of my cooling system, And it could be that I have a little bit of pressure in my expansion tank because i have it topped up to overflowing in an attempt to clear any airlocks. And yes I have all the return pipes and other pipes as you would expect. I would be happy to send a pic if you like. So the interior heat, I can turn off the AC which is first thing I would do. We have no need in this country.
So pressing off/auto together does still bring up 88 88. But apparently my car is unique lol.
I have decent heat in the left side but cold on the right. Ive tried every combination of airflow to window, floor, vents. Even full heat to right and lo to the left. Thermostat faulty on the right side maybe?
Old Nov 29, 2017 | 04:54 PM
  #33
I had a 1995 Integra. I don't remember for sure, but I don't think it started the AC automatically when you selected defrost.
We had a 1998 4-cyl Accord. When you select defrost, the AC lamp would light up, but then you could switch it off.
We had a 2003 4-cyl Accord. When you select defrost, the AC lamp would NOT light up, but the compressor DID begin cycling. And you couldn't switch it off.
So Honda/Acura has used different programming philosophies at different times.??
Old Nov 29, 2017 | 06:33 PM
  #34
I tell you this...I think the whole system, the satnav, blue tooth and HVAC is unbelievably poor. I hate that touch screen thing. I like old fashioned ***** and proper buttons lol
Anyway whatever the quirks of HVAC, I have a fault of some kind somewhere and may yet end up at the dealer for a diagnostic check.
I had my Honda upgraded for performance. Its about 200 bhp Brilliant, so Ill persevere and get the heat fixed
trisketaccord
Feb 12, 2012 09:19 PM
gogihonda
Nov 18, 2011 05:20 PM
BHoward711
Apr 12, 2010 08:57 PM
natew51
Jan 19, 2010 09:16 PM
shabba
Sep 9, 2009 09:42 PM
