transmission cooling lines
Old Nov 27, 2017 | 01:56 PM
hlockquiok's Avatar
Default transmission cooling lines
1990 with 125k miles. I've got a leaking transmission cooling line (passengers side). The original line in metal. I can't find a replacement at rockauto, the Autozone only has a rubber line.
Any idea if I can replace with rubber or where to get a metal line from or some other form of fix?
Old Nov 27, 2017 | 02:41 PM
shipo's Avatar
Rubber, assuming it is rated to deal with ATF, should work. That said, you should be able to call around to some transmission shops who can custom bend metal tubing for you and put in a new set of metal lines.
Old Nov 29, 2017 | 09:23 PM
hlockquiok's Avatar
Thanks Shipo. Got some rubber replacement hose and swapped it out. Good as new!
skydrvr
May 5, 2017 03:33 PM
OLDERTUNER94
Aug 13, 2012 06:30 PM
Big Tex
Sep 8, 2008 09:42 AM
DoctorSub
Aug 3, 2006 09:40 PM
ballistic
Jul 13, 2006 03:50 PM
