2007 Alarm won't activate
Old Mar 13, 2015 | 09:51 PM
bkzfinest_99's Avatar
Default 2007 Alarm won't activate
My 2007 Accords battery died so I got a jump start. Though everything was good until I tried to activate the alarm from the key fob unsuccessfully. Not sure if this is because I got it jump started. Sorry if this is in the wrong forum but any and all assistance would be appreciated. Thanks
Old Mar 14, 2015 | 10:17 AM
A weak battery can cause problems w/ the alarm system. You should have battery tested to be sure weak battery is not the problem.
It may be necessary to reset the alarm system (check owners manual), but removing battery negative cable should cause a reset.
Old Mar 15, 2015 | 11:02 PM
Default I'll give it a try tomorrow
Thanks For your assistance. The sun will be out tomorrow so Autozone says they can check and charge the battery free of charge. I will let you know if it works out. Thanks again
Old Feb 19, 2024 | 05:23 PM
jscarpa's Avatar
What was the fix here? I am having the same issue. The alarm wont activate after a jump start.
Old Feb 25, 2024 | 10:39 PM
nomad2020's Avatar
How to reset the anti-theft system on the Honda Accord?
Insert the key into the driver’s side door lock. Turn it to unlock, then back to lock. Repeat the process. Turn it to unlock again. The system should now be disabled. You’ll need to start the car and leave it running for at least 10 minutes to reset the system.
Try this hope it works
guugoo
May 30, 2011 06:44 PM
R0CKY
Dec 6, 2010 08:59 AM
xang0
Jul 6, 2009 03:22 PM
tordoff
Jan 13, 2009 11:53 PM
colten114
Jan 25, 2008 10:29 AM
