2007 Honda Accord Ignition problem
Old Oct 9, 2021 | 01:21 AM
Jacara's Avatar
Default 2007 Honda Accord Ignition problem
BADLY need help
I have a 2007 Honda accord, the ignition key won't turn the ignition lock, it doesn't feel like the steering lock is on as the wheel moves left and right some.
The key works in the door lock just fine. I did have some problem inserting the key so sprayed it with wd40 and now it goes in and out but it still won't turn the ignition cylinder.
I've also replaced the battery in my key.
Old Oct 9, 2021 | 11:12 AM
Can you release the shift lock and get the transmission in neutral then get the key to turn? Do the brake lights turn on when you push the brake pedal?
Old Oct 9, 2021 | 11:29 AM
Jacara's Avatar
No key will not turn at all, others have suggested that it is probably a stuck waffer in the key cylinder.
Melissa Kaye White
Feb 18, 2014 10:09 PM
Bellbuoy
May 5, 2013 09:59 AM
cchandler
Jan 23, 2013 11:27 PM
cjbened
Sep 6, 2010 05:20 PM
captainfalco
Jan 27, 2007 01:49 AM
