2007 Maintenance MInder Dead?
Old Jan 14, 2019 | 10:06 AM
CHUCKW's Avatar
Default 2007 Maintenance MInder Dead?
Hi all, I've got an '07 2.4 and I am waiting for the maintenance minder to come on to perform basic maintenance but it hasn't come on in quite a while. Does this thing still work after 187k miles? I chained the air and cabin filter at 150k and am still waiting for mm2 to pop up.
Old Jan 15, 2019 | 08:49 AM
I forget exactly how, but there's a way to display the remaining oil life in %. Is that percentage number is decreasing as you drive?
Old Jan 15, 2019 | 09:23 AM
Seanjordan20's Avatar
You just press the trip until it displays the oil life 2 or 3 times depending what is currently displayed
Old Jan 15, 2019 | 08:11 PM
CHUCKW's Avatar
Yes, that number is decreasing as I drive. It just seems like such a long time since I got the message to change the air or cabin filter or anything else other than the oil change.
Old Jan 16, 2019 | 08:46 PM
EXV6NIGHTHAWK's Avatar
You say "it seems like such a long time", but any idea exactly how long (miles, time) it's been? When you did the air filters, did you do an oil change then?
Old Jan 17, 2019 | 10:05 AM
It will not tell you to do those filters separately, it will wait for the next oil change. Then it will display a number along with the A or B for oil change. Something like this, but check your owners manual for the actual list...
A = oil change (personally I wouldn't change the oil without changing the oil filter)
B = oil change with oil filter
B 1 = oil change with oil filter PLUS all the stuff listed under service #1 in the book
B 1 2 = everything from "B 1" plus the stuff from service #2.
Actually, if I remember from my kids' Civics, it's not in the "owners manual" but rather it's in the "warranty & maintenance" book or something like that.
Old Jan 17, 2019 | 04:10 PM
CHUCKW's Avatar
Thanks for the feedback. I changed both the cabin and air filter 37,000 miles ago, not the same as oil change.
I've been waiting for the correct code to pop up but nothing so far.
Old Jan 18, 2019 | 09:36 AM
The maintenance minder only keeps track of mileage and driving habits (long trips, short trips, how many starts, etc). It doesn't actually measure anything related to the oil or filters. So if you change it when the minder doesn't tell you, it has no way of knowing that you changed it. It'll remind you on the interval that it is programmed, NOT based on when you last changed it because it doesn't know you changed it.
Old Jan 19, 2019 | 09:35 AM
CHUCKW's Avatar
Yes, I know but it has been over 37,000 miles and the filter codes have not come up. I just went ahead and changed them both. I was trying to wait until the minder popped up but I couldn't wait any longer than 37,000 miles, that just seems crazy.
Old Jan 23, 2019 | 09:38 PM
Yeah, I'd probably do the same. At least take the filter out & look at it...
HigherEd
Aug 23, 2013 03:08 PM
mj11a
Oct 30, 2011 10:50 AM
jackkpts
Feb 19, 2008 02:47 PM
BlackZ51Vett
Sep 28, 2007 03:39 PM
rob3201
Jan 31, 2007 04:46 PM
