2008 4 door accord and my wipers stopped working.
Old Dec 29, 2013 | 02:57 PM
Cristine_G's Avatar
Default 2008 4 door accord and my wipers stopped working.
I have a 2008 4 door accord and my wipers stopped working. the fuse is fine so I'm thinking its the relay. Any idea where that might me located?
Old Dec 29, 2013 | 04:02 PM
I created a new thread for you since it is a different issue than where you posted originally.
There are actually several fuses in the circuit for the wipers. The No. 4 (7.5A) fuse and the No. 5 (7.5A) fuse in the driver's side interior fuse box. (See attached image.)
Then, there is Fuse 3-2 (30A) fuse which is part of a combined fuse box (replaced as a unit), located in the under-hood fuse box. (See the two attached images.)
Check all these fuses first.
It is less likely to be the relay. In addition, the wiper relays are part of a relay unit (replaced as a whole), located in the under-hood fuse/relay box. Part #18 in this parts diagram.
If the fuse(s) check fine, since the wiper/washer system is part of the multiplex integrated control system, you may want to try a battery cable reset to see if it changes anything.
Battery cable reset: Disconnect the negative cable (disconnect negative first) and then positive cable. Then connect them together with a jumper wire for 15 minutes. -- Do not touch the battery terminals. You will need the radio security code afterward.
Attached Thumbnails 2008 4 door accord and my wipers stopped working.-interior-fuse-box.jpg   2008 4 door accord and my wipers stopped working.-underhood-fuse-box.jpg   2008 4 door accord and my wipers stopped working.-combined-fuse-box.jpg   2008 4 door accord and my wipers stopped working.-control-unit-engine-room-1-l4-469516.jpg
yeah yeah
Jan 20, 2015 04:14 PM
19962door
May 7, 2012 12:43 PM
Jcaleno
Feb 1, 2012 07:18 AM
Brian P.
Jul 19, 2011 01:43 PM
