2008 Accord-LX: steering wheel vibrations
Old Feb 15, 2014 | 03:56 PM
New0wner's Avatar
Default 2008 Accord-LX: steering wheel vibrations
I've got a 2008 Accord-LX. It is the regular 2.4L (?) engine with the 5-speed automatic. Something is wrong with it. When I accelerate from a dead stop, I can hear whop-whop noise coming from the front end, and the steering wheel vibrates badly. This happens up through roughly 45MPH, and then is no longer noticeable - UNLESS I go up a steep grade, then it is noticeable again.
The car first starting doing this on 2/1, after I hit some black ice and the traction control system came on. I "powered / accelerated" through it, and that is when the vibration started. I immediately took it to a Midas, and they checked the car out for me - including the wheel bearings. They didn't note anything out of the ordinary.
I hit another patch of black ice on 2/6, and again the traction control came on, and I "powered / accelerated" through it. Well, now the vibrations are roughly four times as bad as they were, previously... I drove with the window down on 2/8, and you can't really hear anything from the street level - outside of the engine spooling up.
I think I did something with the linkage / drivetrain, between the engine and the transmission. Thoughts?
Old Feb 15, 2014 | 06:56 PM
CV axles are a likely cause. You may be able to simulate by raising the front end on jack stands and accelerating wheels while observing CV axles. Quality cv axles (not rebuilt) are recommended.
I would also inspect front and rear motor mounts for faults to rule them out. Inspect w/ trusted helper holding the brake and pulsing the throttle while you observe from side for excessive movement of engine at mount and for mount damage.
amajakgar
Aug 9, 2014 09:22 AM
loki16
Aug 12, 2013 06:54 AM
irl5fan
Feb 27, 2013 05:29 PM
MessAround
Jun 18, 2011 11:19 PM
