2008 Accord mifire fault
Old May 11, 2017 | 10:59 PM
silentsay's Avatar
Default 2008 Accord mifire fault
Hello!
My Accord show me the engine check lamp and my car power decreas.
So I check OBD than show me fault p0300, p0302, p0303.
I did change ignition coil No.1 -> No.2 and No.3 -> No.4 .
and eraise DTC, start engine but after fue minuits show me engine check lamp.
I did scanning again fault p0300, p0302, p0303 show again!!
I did change injector the smae way No.1 -> No.2 and No.3 -> No.4.
and erais DTC, start engine after fue minuits show check lamp and smae DTC fault.
So I change crankshaft position sensor and delete history value.
3 days Ok...
But... show me check lamp and same DTC again..
Please!! Some body help me!!
P.S> show me check lamp and evrytime same DTC but engine not shaking.
Old May 12, 2017 | 09:30 AM
You are off to a good start with swapping coils to see if the misfire changes. I don't think you needed to change the crankshaft position sensor, because you had no code and you didn't do any testing on it. Changing working parts can complicate diagnosing the problem.
How many miles are on the engine?
tiredredcoupe
Dec 26, 2009 03:09 PM
skuffknee
Feb 7, 2009 07:10 PM
mike63
Jan 2, 2009 01:09 AM
mrbthebarber
Oct 29, 2008 03:03 PM
larrysnach
Mar 11, 2006 10:48 PM
