2008 Honda accord k24z3
Old Jun 8, 2020 | 05:08 PM
Addison27's Avatar
Default 2008 Honda accord k24z3
I have a 08 accord that i put a new timing chain, tensioner, head gasket, and starter on it starts right up runs perfect so hesitation or shaking and can idle and rev it for hours but when i got to drive it for like 3 min then it goes in limp mode saying it has a misfire on cylinders 1 and 4 note the head and valves are good checked them when i did the head gasket could it be loaing fuel pressure somewhere?? Never seen a car read a misfire when it doesnt run rough at all
Old Jun 8, 2020 | 05:17 PM
Why did you replace the timing chain and head gasket?
Old Jun 8, 2020 | 05:19 PM
Addison27's Avatar
I got it from a guy that said it jumped time and it has 258k miles so i just go ahead and replaced it all while i was checking the motor put water in the exhaust and intake ports with the head off and no water leaked through any of the valves
Old Jun 8, 2020 | 05:28 PM
Did you have the cylinder head milled, so it was perfectly flat before you reinstalled the cylinder head?
Have you run a compression test on the cylinders?
Old Jun 8, 2020 | 05:33 PM
Addison27's Avatar
No i didnt have the cylinders milled they didnt have any play in them and the pistons arent flat there raised in the 4 corners if that makes any sense im doing a compression test in the morning but the freeze frame on the scanner said fuel system 1 OL
Old Jun 8, 2020 | 06:30 PM
Addison27's Avatar
It can have it idling in park and rev it as high as i want for hours with no hesitation or smoke no leaks and no check engine lights till i go to drive it for about 3 mins
Old Jun 8, 2020 | 09:36 PM
I was asking if you had the cylinder head milled, so the cylinder head is perfectly flat where it contacts the head gasket. Or did you check with a straight edge that the cylinder head was flat?
Old Jun 8, 2020 | 11:55 PM
Addison27's Avatar
Update all the senors were not in sync some how got them all to reset and havent had a problem yet.
Old Jun 8, 2020 | 11:58 PM
Addison27's Avatar
The crankshaft sensor was not in sync so im guessing its going bad all cylinders had perfect compression
mancar72
Jun 25, 2014 01:51 PM
barhillsman
Jul 21, 2011 07:26 PM
Shag Wagon
Oct 12, 2010 03:37 PM
summerfish2001
Dec 4, 2008 02:25 PM
KD
May 9, 2008 06:21 PM
