2008 Honda accord k24z3
I have a 08 accord that i put a new timing chain, tensioner, head gasket, and starter on it starts right up runs perfect so hesitation or shaking and can idle and rev it for hours but when i got to drive it for like 3 min then it goes in limp mode saying it has a misfire on cylinders 1 and 4 note the head and valves are good checked them when i did the head gasket could it be loaing fuel pressure somewhere?? Never seen a car read a misfire when it doesnt run rough at all
I got it from a guy that said it jumped time and it has 258k miles so i just go ahead and replaced it all while i was checking the motor put water in the exhaust and intake ports with the head off and no water leaked through any of the valves
No i didnt have the cylinders milled they didnt have any play in them and the pistons arent flat there raised in the 4 corners if that makes any sense im doing a compression test in the morning but the freeze frame on the scanner said fuel system 1 OL
