2012 Accord - license plate bolts/screws?
Old Jan 21, 2012 | 01:50 PM
user91's Avatar
Exclamation 2012 Accord - license plate bolts/screws?
I purchased a 2012 accord sedan last night. I need to put my license plates on and I can't tell if the holes are metal with fine threads or they are plastic and you just turn any screw into them or what.
Of course I have the dealer advertising license plate frames which have a big coarse threaded bolt head screw but it doesn't look "correct" although I'm sure it would work.
Hopefully someone knows the proper length bolt or screw to use? And the threads - metric, fine/coarse, etc. or maybe it doesn't matter?
Thanks,
Paul
Old Jan 21, 2012 | 03:54 PM
This is for the 2011 accord, because the 2012 parts list is not up on the OEM parts web site.
The part for the license plate screw is #43 for the rear license plate. It looks like a coarse threaded screw.
43 93913-25320 SCREW, TAPPING (5X4) (PO) USA 2 $0.45 $0.33
Old Jan 21, 2012 | 04:03 PM
user91's Avatar
There are four license plate holes, but they say only two screws?
These would be the screws that hold the license plate on, correct?
Do you know if 5x4 is metric or usa?
I want to get stainless steel ones from the hardware store.
Sorry for being a pain and I really appreciate your help!
Thanks,
Paul
Old Jan 21, 2012 | 04:55 PM
I found that Majestic Honda has the 2012 parts website.
The OEM part number for the screw is:
93913-25320
It costs about $0.50, so you might want to buy one screw from the dealership to have the exact screw when you go to the hardware store.
Old Jan 21, 2012 | 05:08 PM
IIRC the bolts for the rear license plate are M6 - 1.0 x 20mm. You can pick them up at any hardware store or auto parts place. You only need the top two to hold the plate on.
The front screws are different.
Old Jan 21, 2012 | 06:16 PM
user91's Avatar
I got some 5x4 screws and bolts just in case and they went right through - too small.
I'll try the M6. Any idea which size front screws/bolts I need?
Old Jan 21, 2012 | 06:55 PM
The front may be M6 x 16 self-tapping screws.
For the rear, M6 - 1.0 x 20mm, the 1.0 is the thread pitch and the 20mm is the length.
Old Jan 22, 2012 | 09:43 PM
user91's Avatar
The M6 - 1.0 x 20mm worked great for the rear and they look great in stainless steel. The open holes at the bottom of the plate bug me, so I'll have to do something about them.
The front do appear to be screws, they screw into a soft plastic frame.
Thanks,
Paul
spnyi
Jul 30, 2020 01:13 PM
Sonic
Nov 1, 2012 08:06 PM
mgobluefan79
Apr 29, 2012 10:45 AM
bjanecek
Aug 20, 2008 04:09 PM
emaxxman
Mar 9, 2006 12:52 PM
