2013 Accord MT Gas Pedal Extension
Old Sep 28, 2014 | 01:16 PM
Savage_xRDs's Avatar
Default 2013 Accord MT Gas Pedal Extension
Hey mates.
Searching around on the internet for the last couple of days seems to have turned up nothing, so I was wondering if any of you encountered the same issue as me.
As many of my fellow Accord manual drivers may have noticed, the pedal arrangement on the stickshift 2013 Accord puts the gas pedal almost exactly 2 inches behind the brake pedal. Having an unhealthy addiction to driving stickshift as I do, I find this extremely frustrating in the heel-toe department. Reaching the gas pedal as far back as it is forces me to nearly threshold brake every time, which is not always what I'm looking to do.
So, I was looking around for thicker pedal pads for the throttle pedal, or maybe even a 2" extension, but looking at the pedal itself, I found that it has no cover and is instead a solid piece on the front, back and right side of the pedal and has lateral ribs giving it rigidity and thickness. So unlike the clutch and brake pedals that have the standard rubber covers on them, the gas pedal literally has no cover nor screw holes.
The question is as follows: have any of you managed to find a way to extend the pedal length so that it is in line with the brake pedal? I would prefer to steer away from various epoxy or rubber cement options...that I'll save if nobody has any ideas.
Vehicle info: 2013 Accord Coupe LX-S Manual.
Thanks in advance.
- Savage
Old Sep 28, 2014 | 01:26 PM
No need to heel-toe w/ a convenient e-brake to hold car.
However, you might try strapping some old flip-flop soles cut to fit the pedal.
Plastic wire ties could secure the pieces temporarily for trials. You may not like the arrangement or it may have unanticipated consequences. Wood screws w/ washers could permanent attach to pedal.
Best to remove pedal to install this spacer.
Old Sep 29, 2014 | 10:25 PM
Thanks for the reply, mate.
I'll see how the temporary trial setup goes as I want to give it a shot anyway. If it proves worthwhile, I'll go about making something more permanent.
Thanks again!
- Savage
Old Sep 30, 2014 | 08:09 AM
One final caution. In the US, a modification like this might cause problems if you had an accident. It might invalidate coverage of damage to your own vehicle. I don't know this for certain, but its something to check.
Of course folks here lift and lower, change wheels/tires, modify PCMS, etc so it probably is no diff for you.
bambooyou
May 30, 2012 09:47 PM
eichhoma
Dec 9, 2009 05:32 PM
emmee
Aug 29, 2007 03:23 PM
gypsyman
Jun 4, 2007 05:39 PM
TedsF23accord
Jan 10, 2007 06:23 PM
