2013 Accord, shift lever locks up in park
Old Aug 17, 2017 | 09:43 PM
Rick's ride's Avatar
Default 2013 Accord, shift lever locks up in park
Hi, I've had this vehicle 6 months now, and the shift lever has locked up on me 3 times. My service advisor is trying to convince me I am accidently bumping the brake pedal getting into the vehicle? If a wait a few minutes the lever will release on it's own allowing me to shift out of park and off I go! I have to take the vehicle back to Honda Monday for the Battery Sensor recall and I would like to have them check out this shift problem. Sometimes, these service advisors come up with standard explanations which might convince themselves, but not the customers. They tend to turn a deaf ear on customer complaints!
Accord is a 2013 EX-L V6 with the push button start.
If anyone out there has had this problem, I would appreciate any info you might have!
Thanks - Rick
Old Aug 17, 2017 | 09:54 PM
I'm guessing that you can't shift the car out of park? When the problem occurs, check that your brake lights are actually working when you press on the brake pedal.
On older accords, there was a cover near the shifter that you removed and inserted your key to manually bypass the shift lock. You 2013 accord may have this. Take a look in the owner's manual to verify.
Old Aug 20, 2017 | 11:41 AM
rjaccord's Avatar
My 2011 has that manual override slot. Been using it this week.
My AT is locked up too.
The 2013 should have that override slot as well.
panoman
Dec 7, 2012 06:45 PM
wifes01
Aug 17, 2011 04:16 PM
clim53
Nov 9, 2010 10:09 PM
19962door
Nov 12, 2009 09:27 PM
foxylady23
May 14, 2008 12:50 AM
