2016 Accord Brake Warning light on
Old May 28, 2022 | 08:32 PM
dctaz37's Avatar
Default 2016 Accord Brake Warning light on
The brake warning light came on. How do I troubleshoot this? E-brake isn't on, fluid is okay and brakes aren't sponge.
Old May 28, 2022 | 08:35 PM
Is this the same light that turns on when the e-brake is engaged, or a different brake light?
Old May 28, 2022 | 08:41 PM
dctaz37's Avatar
Same light? Are there different lights?
Old May 28, 2022 | 08:54 PM
I don't know the 2016 cluster setup, but on older accords there were two lights. The e-brake light and brake lamp light. The brake lamp light indicated you had a brake bulb out.
Old May 28, 2022 | 09:08 PM
dctaz37's Avatar
I don't yet have a manual for this car so I will check the brake lights,. The wife gave me the wrong information. It isn't the e-brake light. It is an orange warning light, looks like a horseshoe with a ' ! 'in the middle. Maybe someone else is familiar with this particular cluster and pipe in. Thanks for your response.
Old May 28, 2022 | 09:14 PM
Low tire pressure light. Check your tire pressure (including the spare). Add air to the tires. The recommended psi should be on a sticker in the driver's door frame.
EDIT: You can also find the 2016 owner's manual online from honda. Just google 2016 accord owner's manual to get a pdf for your car.
Old May 28, 2022 | 09:24 PM
dctaz37's Avatar
Thanks, I'll check tomorrow.. Ya I just looked up the code, sorry for the misinformation. My wife said she looked it up but obviously got the wrong code.
CapsRyd
Mar 7, 2022 11:17 AM
garyjatt13
Sep 10, 2009 10:18 AM
poolman
Jan 14, 2009 05:44 PM
xHondaTHiZz
May 21, 2007 10:13 AM
herzy23
Sep 12, 2006 04:21 PM
