brake light warning is on
Old Sep 9, 2009 | 01:07 PM
garyjatt13
Default brake light warning is on
2003 honda accord ex 4cly
I had changed my brake fluid about a week ago and noticed yesterday the brake light warning was on. i kno it was not on before i changed the brake fliud, how long after im not sure. So I checked the brake fluid and that was full and then I checked all the brakes and they are all good so I don’t kno what else it might be. And I how I could fix it. Any help would be greatly appreciated thank you.
Old Sep 9, 2009 | 03:33 PM
What warning lamps, does it say "BRAKE LAMP"? That one's for burned-out bulbs at the back of the car.
Sometimes a brake light is getting flaky, and the wattage changes before it burns out completely. That warning comes from measuring wattage side-to-side, so if all the bulbs seem OK it may be that they just don't match each other.
This probably won't become a long detailed PROCEDURE, so I'll move it to General Tech where it belongs.
Old Sep 9, 2009 | 11:55 PM
garyjatt13
sorry about that. the red letters that say "Brake" on the dashboard the ones that come on when the e brake is on. thanks for the help
Old Sep 10, 2009 | 07:11 AM
The sensor's in the side of the brake fluid reservoir. Check if it's pluged in or ??
Also, check the little switch at the handbrake lever - it might be bent or something.
Old Sep 10, 2009 | 10:18 AM
deserthonda's Avatar
you might have to replace the brake master cylinder ,,,not sure if you can get the sensor separately
MikeT
Aug 31, 2012 10:59 AM
dmjole
Aug 21, 2012 06:02 PM
chillnndc
Sep 15, 2011 07:07 AM
hmr
Jul 24, 2011 07:19 AM
ropersc
Feb 18, 2011 03:09 PM
