2016 Accord-Engine wind deflection tray(required?)
Old Sep 13, 2025 | 03:45 PM
dctaz37's Avatar
Default 2016 Accord-Engine wind deflection tray(required?)
I've been struggling every time I change the oil with the screw/fasteners that hold the tray on. I bought new male and female ends but they still won't fasten properly. Is this tray necessary? Has someone come up with a better system to fasten this plate? I can't believe they would make such a crappy design.
Old Oct 6, 2025 | 01:17 PM
dctaz37's Avatar
No replies, does that mean I'm the only one with this issue?
Old Oct 7, 2025 | 02:27 PM
Are you asking about the plastic shield under the engine to access the oil drain bolt?
Old Oct 7, 2025 | 03:29 PM
dctaz37's Avatar
It is a metal wind shield and yes to access drain plug and filter.
Old Oct 9, 2025 | 08:30 PM
I'm not familiar with the 2016 setup. Haven't seen any complaints about it on here. It helps with aerodynamics, but I'm not sure how you can improve fastening.
KenC
Feb 7, 2024 03:08 PM
dctaz37
May 15, 2023 04:26 PM
dctaz37
Mar 24, 2022 11:20 PM
fskilesjr
Mar 8, 2021 05:45 PM
tcollins9
Sep 7, 2016 12:55 PM
