2237 fault code
Old Dec 22, 2008 | 11:54 AM
2fargone
Default 2237 fault code
'03 accord exauto v6 getting a 2237 fault-which sensor is this code referring to????
Old Dec 22, 2008 | 01:00 PM
finch13's Avatar
Old Jan 15, 2009 | 10:29 AM
lberkoski
Default RE: 2237 fault code
Hi, I just got the same trouble code P2237 (Autozone said it was AF sensor DIP line high voltage -12, Open or short circuit or Failed AF sensor) - and I'm trying to determine the location of the sensor to determine cause. Could there be an indirect cause for this? I replaced the Air Filter with an aftermarket one about three weeks ago - I am wondering if a) I damaged the sensor/wiring replacing the filter or b) the air flow is now different due to an aftermarket filter difference, resulting in a "fault" condition.
Old Apr 17, 2011 | 03:04 PM
Kaell's Avatar
I think this is the A/F (aka O2) sensor that you see from top of engine bay close to firewall (not the one in front near radiator).
I too have this code and am working on fixing it but having some trouble.
First, I cannot get the electrical clip disconnected. I push on the tab and pull as hard as I can but nothing moves. I've tried on the front one as well B2S1 even though it isn't bad just to see if I could get that clip off. I've wedged a flathead tip in there and can get a tiny bit if separation but it just goes right back when I release pressure. Is there a trick to disco these?
Second, what part/parts can/should I use to replace it? Can I use a Bosch 15730 4-wire O2 sensor even though this is a 5-wire A/F sensor? Do I then just combine the black/ground wires? Can I use a Bosch 15401 OE sensor? Or do I need a sensor from Honda?
Third, I can just use a 3/8" wrench to remove sensor, right? No need for an O2 socket.
Thanks for reading and hopefully responding!
-Kaell
Old Apr 17, 2011 | 09:23 PM
The location of the sensor depends on the year of the car, and whether 4-cyl or V-6...??
You won't want to use a generic sensor with the wrong number of wires.
Old Apr 18, 2011 | 02:39 AM
Kaell's Avatar
Same as OP. 2003 Accord EX V6 Auto. I'm fairly certain on the location for this car for B1S1.
I think I'm going to go with the Bosch 15401.
Old Apr 18, 2011 | 07:09 PM
Denso seems to make the sensors for Honda. I haven't used Bosch & don't know their part numbers.
Sensor 1 is at the top of each catalyst, against the head. Sensor 2 would be below each catalyst. But I'm not sure of the numbering of bank 1 vs bank 2.
It might be in there pretty tight, so a normal wrench might not cut it. If the wire fits through a closed-end wrench, go for it. An open-end wrench might round off the sensor hex.
Old Apr 18, 2011 | 07:56 PM
On the six cyl, bank 1 is on the back side of the engine
2fargone
Jun 8, 2008 10:18 PM
billvaughn
Jun 1, 2008 07:57 PM
AccordNSTL
Apr 30, 2008 03:55 PM
Koko
Feb 15, 2008 08:57 PM
appleman
Sep 27, 2007 11:44 AM
